Adding the Content Containers Module
About
Content Containers is a SmartHub module located in the modules directory - <SmartHub_root>\modules. SmartHub Content Containers replaces the Content-By-Search feature.
Note: Content-By-Search code is still supported. Any existing CBS structure will continue to function.
Supported templates are HTML (underscore)
Content Containers:
  • Can be rendered event-based, anywhere on the page
  • A single SmartHub page can contain multiple Content Containers
  • Configuration is based on the standard settings files (Index.js, Results.js settings files).
  • Modifying HTML pages (Results.html / Index.html) is unnecessary.
How to Configure the Content Containers Module
Modify an Existing Content Container
The easiest and fastest way to work with content containers is via the SmartHub UI Editor.
Procedure:
  1. SmartHub administrators can simply click the UI Editor link from the SmartHub ADMINISTRATION page.
  2. Click the Select a page link from the top menu.
  3. Select (double-click) the page (Index.html, landing.html, etc.) you wish to modify.
    1. Below, the Results.html page is shown for sample purposes.
    2. BA Insight recommends you create your own custom page (within its own folder) to modify. Leave the default files as templates.
  4. Select the Customize ContentContainers tab from the top of the page.
  5. Two pre-defined containers appear:
    1. ChatBotCbs
      • This container controls Best Bets and other chat bot and content-by-search functions.
    2. MainResults
  6. After making changes you must click both Apply and then Save changes (bottom left corner) for your changes to take effect.
Create a New Content Container
Procedure:
  1. To create a new Content Container, from the default Customize ContentContainers page click the '+' icon.
  2. Enter an ID (name) for the new Content Container.
  3. Select the Content Container type.
  4. Select the Content Container position.
  5. Select the Content Container settings, as desired.
  6. Click Apply. The dialogue closes.
  7. Click Save Changes.
Content Containers Parameters
Setting Name Default Value Description
PreviousLabel "Previous" The tool-tip of the "Previous" button.
NextLabel "Next" The tool-tip of the "Next" button.
SortLabel "Sort by: " The text displayed in the sort section.
CollapseLabel "Collapse" The tool-tip of the "Collapse" button.
ExpandLabel "Expand" The tool-tip of the "Expand" button.
CloseLabel "Close" The tool-tip of the "Close" button.
NoResultsLabel "Sorry, no results found!" The message displayed when there are no results for the performed search.
UserProfileServiceURL SH.RootLevelURL + "/Services/UserProfileService.svc" The URL for the user profile service (required for Analytics).
ContentContainers
SampleCBSWithDefaultValues
- The list of Content Containers that will be rendered. The content container name is not important, you can name it however you like.
ParentContainerSelector
'.sh-main-results-container' The parent selector used for the appending of the compiled template of the container.
Title 'Content Container' The displayed name for the content container.
ControlTemplatePath SH.RootLevelURL + "/modules/ContentContainers/templates/cbsControlTemplate.html" Content Container template path. You can customize the template and provide the path to the custom template using this parameter.
ItemTemplatePicker function (result) { return SH.RootLevelURL + "/modules/ContentContainers/templates/cbsItemTemplate.html"; } The function which allows choosing which template to load based on the item metadata.
QueryTemplate '{searchboxquery} FederatorBackends:"*"' The query template to use when executing the query.
SourceId 'b29924a9-ec32-4c10-8892-a544b69ee121' The query results source ID to use when executing the query. If it is left empty the current tab ID is used.
FieldsToInclude 'clickUri, title, Rank, ContentSource, FileExtension, excerpt, SDFUrl, date, DisplayAuthor, isUserProfile, WorkEmail, Title, JobTitle, Department, AboutMe, escbasecrawurl, UserName'
These are query.SelectedProperties requested with each search query.
If you want to return all existing properties of an item use "ALL" as value for .
RequestedNumberOfResults -1
This specifies the number of results that are requested in a query. If the value is set to -1, this setting is disabled and the number of requested results are controlled by the RowsPerPage setting.
Note the following regarding pagination:
  • If the RequestedNumberOfResults parameter is not enabled (value is set to -1), the number of results that are returned when the page is changed is controlled by the RowsPerPage parameter.
  • If the RequestedNumberOfResults parameter is enabled, SmartHub will first paginate the requested results. If the user requests additional results that exceed the number of requested results, a new query is executed.
  • For example, if RequestedNumberOfResults is 50 and RowsPerPage is 10, The initial query will request 50 results which will be rendered in 5 pages with 10 results per page. If the user attempts to access the 6th page of results, a new query is executed.
ShowRowsPerPage false When this is set to "true", the Rows per page control will be available to users to change the number of search results returned.
RowsPerPage 10,20,50 This is a list of numbers that specifies the amount of items that are requested during a query. By default, the initial amount of items requested is the first value from the list. The RowsPerPage control will show the values of this setting as options to be selected.
RowsPerPageLabel "Results per page: ".toLocaleString() This specifies the label text that appears before the dropdown control that allows the user to select a number of items.
EnablePagination false
true - Pagination control is displayed on the container.
false - Pagination control is hidden.
EnableSmartPreviews true
true - SmartPreviews functionality is enabled. The items support showing a binoculars icon which shows the SmartPreviews Viewer when clicked on.
false - SmartPreviews functionality is disabled.
ShowSort false
true - Sort control is displayed on the container.
false - Sort control is hidden.
AllowUserActivation true
true - Container shows in the "My homepage" section and can be disabled or enabled by the user.
false - User cannot choose to enable or disable the container. The container is visible by default.
SortProperties 'Rank#Most Relevant#descending,date#Newest#descending,date#Oldest#ascending'
This specifies a comma separated list of properties available for sorting. These must be sortable properties in the search engine. The first property in the SortProperties list is used as the default sort property.
The SortProperties setting supports the following formats:
  • Label Format: This format specifies the property name, its user interface label, and the sort direction, separated by #: <sort_property_1_name>#<sort_property_1_label>#<sort_direction>,<sort_property_2_name>#<sort_property_2_label>#<sort_direction>,etc. For example, Rank#Relevance#descending, date#CustomNameForDate#ascending
  • Basic Format: In this format, only the property names are specified. The displayed labels are the property names: <sort_property_1_name>,<sort_property_2_name>,<sort_direction>. For example, Rank,date,descending.
  • Mixed Format: In this format, a combination of basic properties and labeled properties are specified: <sort_property_1_name>#<sort_property_1_label>,<sort_direction>,<sort_property_2_name>,<sort_direction>. For example: Rank,date#CustomNameForDate,ascending
TriggerNewQueryOn 'afterInitialization'
The name of the event that, when triggered, will execute a new query and render the results. If left empty, then the Container only renders after being invoked via API.
Examples of events: afterInitialization, deferredQuerySuccess or any custom event.
EnableCountTotal false
- The total count is displayed on the container.
- The total count is hidden.
EnableContentIntelligence true
true - ContentIntelligence functionality is enabled. The items will support showing an info icon which shows a modal with details of the result when clicked on.
false -ContentIntelligence functionality is disabled.
EnableResultFeedback true
true - ResultFeedback functionality is enabled. The items will support showing a feedback icon which shows a feedback form when clicked on.
false - ResultFeedback functionality is disabled.
EnableRatings false
true - Ratings functionality is enabled. The ratings of the results will be displayed.
false - Ratings functionality is disabled.
EnablePubChemViewer false
true - PubChemViewer functionality is enabled. The items support showing a button labeled "3D Model" which shows the PubChem Viewer when clicked on.
- PubChemViewer functionality is disabled.
Baskets {'.basketButton':false}
true - Baskets functionality is enabled. The items will support showing a button labeled "Add to basket/Remove from basket" which adds/removes the item to/from the basket when clicked on.
- Baskets functionality is disabled.
IsMainResults false
true - The content container contains the main results.
false - The content container doesn't contain the main results and behaves like a normal CBS.
DeferredRendering false
true - The ContentContainer does not render the results, instead it triggers an event named "ContentContainerDeferredRendering". This event will contain the information about the container Id, container settings and the results, and can be used to handle the result rendering via a custom function.
false - The ContentContainer will use its internal methods to render the items.
Content Containers events and functions
You can use the following events and functions to implement custom changes to your ContentContainer module:
ContentContainer events
All the ContentContainer events can be seen in the SH.ContentContainers.BuiltInEvents object in the ContentContainer.js file.
Event Description
ContentContainerBeforeInitialization This event is triggered before the ContentContainer starts rendering.
ContentContainerDeferredRendering This event is triggered before the results are rendered when the DeferredRendering content container parameter is true.
ContentContainerBeforeQuery This event is triggered before doing a query using SH.SearchProvider.GetDocuments.
ContentContainerQuerySuccess This event is triggered after ContentContainerBeforeQuery and before rendering the results.
newResultDisplayed This event is triggered when a result is rendered.
newResultsDisplayed This event is triggered when all the results are rendered.
Exposed ContentContainer functions
All the exposed ContentContainer functions can be seen at the bottom of the ContentContainer.js file.
Function Parameters Description
SH.ContentContainers.Close containerId This function hides the ContentContainer with the specified id.
SH.ContentContainers.Show containerId This function shows the ContentContainer with the specified id.
SH.ContentContainers.RenderContentContainer containerId, ev, containerSettings, showUserPredefined Result, callback This function renders the ContentContainer with the specified id.
SH.ContentContainers.RegisterNewAction e, newActionConfiguration, callback This function creates and renders a new action inside the action bar for a result.
SH.ContentContainers.GetContentContainers - This function returns the SearchInterface, Results and the content container ID for all the rendered ContentContainers.
SH.ContentContainers.GetContentContainersKeys - This function returns the ids for all the ContentContainers.
SH.ContentContainers.GetContentContainerConfiguration containerId This function returns the configuration for the ContentContainer with the specified id.
SH.ContentContainers.GetMainResultsContentContainerId - This function returns the configuration for the main results ContentContainer
SH.ContentContainers.RefreshCBS containerId, containerSettings, startRow This function performs a new GetDocuments Query and renders the results inside the specified ContentContainer.
SH.ContentContainers.GetContentContainerById containerId This function returns the SearchInterface , Results and the content container ID for the specified ContentContainer
SH.ContentContainers.ApplyDefaultSettings containerSettings This function applies the default ContentContainer settings for all the configuration options that are missing
SH.ContentContainers.GetSortCriteriaForMainResults containerId, containerSettings This function returns the sort criteria for the main results.
SH.ContentContainers.GetSortCriteriaForCBS containerId, containerSettings This function returns the sort criteria for specified ContentContainer acting as a CBS.
SH.ContentContainers.getNumberOfPages totalResults, rowsPerPage This function returns the number of pages.
SH.ContentContainers.GetFieldsToInclude containerSettings This function returns the fieldsToInclude configured for a ContentContainer.
SH.ContentContainers.UpdateConfigurationOption containerId, settingName, settingValue This function changes the value for the specified configuration option.
